This guide contains all permissions and requirements for connecting your Apple Public Data data to Supermetrics.
The Apple Public Data data source connector doesn't require authentication or connection to the App store.
App store
App Store search
App Store reviews
Top App Store apps
Books
Audiobook search
Book search
Top audiobooks
Top books
Music
Music search
Top Apple Music
Top iTunes Music
Top music videos
TV
Movie search
Short film search
TV show search
Top movies
Top TV shows
Top short films
Podcasts
Podcast search
Top podcasts
Other
Top iTunes U courses
When connecting to Apple Public Data, you need to select a query type when prompted.
Select the Apple Public Data data source on the Supermetrics Hub or in the data destination.
In your data destination, select the query type and query details.
You can also connect to Apple Public Data from these destinations:
AI tools and dashboards:
