How to connect Supermetrics to AI tools
You can connect your Supermetrics account to AI tools, such as Claude, ChatGPT, or Google Gemini Enterprise, and ask natural-language questions. This helps you get instant answers based on data from all the marketing platforms you've already connected to your Supermetrics account.
Once connected, the AI chat can access data from any platform you've already connected to your Supermetrics account (such as Google Ads, Facebook Ads, Google Analytics, and more).
What happens in your AI tool and in Supermetrics
When you use Supermetrics in your AI tool, 2 products work together. Your AI tool handles the conversation: it reads your prompt, asks Supermetrics for data, and writes the answer. Supermetrics handles your marketing data: it checks your team and subscription, fetches the data from your data source accounts, and sends it to your AI tool. The Supermetrics MCP server connects the two.
You can do most tasks right in the chat. Data sources you connect in your AI tool also show up on the Supermetrics Hub, and the other way around.
Task
Where
Connect a data source
AI tool or Hub
Select accounts and ask questions
AI tool
Add a data source to your subscription
Hub
To learn more about what happens in your AI tool and what happens in Supermetrics, see how AI tools and Supermetrics work together.
Note the following requirements for using AI chats:
Connect to Claude
To connect to Claude, go to our Claude integration page and click Try in Claude.
Read more about the possibilities of using Supermetrics in Claude.
Connect to ChatGPT
To connect Supermetrics to ChatGPT, go to our ChatGPT integration page and click Try for free.
Read more about what you can do with Supermetrics in ChatGPT.
Connect to Microsoft Copilot
To connect Supermetrics to Microsoft Copilot, go to our Microsoft Copilot integration page and click Try in Copilot.
Read more about setup and use cases in our Supermetrics Marketing Analyst for Copilot setup guide.
Connect to Google Gemini Enterprise
Get in touch with us to discuss enablement for Google Gemini Enterprise.
Learn more about Gemini-specific use cases.
Build your first dashboard
If you're new to analyzing data with AI tools, here's how to go from asking your first question to a dashboard you can save and share. The steps below use Google Analytics as an example, but the same pattern works with any data source you've connected, such as Google Ads or Facebook Ads.
Note
When you make a request, the AI tool may need to use several "actions" from the connector. You may need to manually approve these actions as they appear in the chat for the query to complete successfully.
  1. Before building a dashboard, confirm that the AI tool can read your data and access the right account.
    1. Ask the AI tool to use the Supermetrics connector to fetch your Google Analytics data and select the right account. You can specify the account to use, or ask the tool for the list of accounts it has access to, and then select the one to use. For example:
      • Hi, I’d like to use Supermetrics to build a Google Analytics dashboard. List all accounts you have access to and let me select which one to use.
    2. If the data source or subscription isn’t found, check that you’ve logged in with the right account and connected to the right Supermetrics team. See below for instructions on how to verify you're using the right account.
  2. Once connected to the right account, start with one simple question. Ask something specific and easy to check, for example:
    • How many sessions did my website get last week from Google Analytics?
  3. Turn the answer into a visual representation.
    • Ask the AI tool to build a chart with the same data instead of listing numbers, for example:
      • Show me a line chart of my website sessions for the last 30 days, by day.
    • You can name a chart type (line chart, bar chart, table) or let the AI tool choose one for you.
  4. Add more metrics or charts.
    • A dashboard usually shows more than one thing at once. Ask for a few related metrics together:
      • Add users and average engagement time to the same view, each as its own chart.
    • This is also a good point to bring in a second data source, for example, comparing website traffic against ad spend from Google Ads, or checking Google Search Console data on your search performance.
  5. Adjust how the dashboard looks.
    • You can ask for a different chart type or a specific color scheme, for example:
      • Change the engagement time chart to a bar chart, and use a blue and grey color scheme.
    • You can also ask for a scorecard, which shows one number in large text rather than a chart. This is useful for a metric you want to stand out, such as total conversions or total spend:
      • Turn total sessions into a scorecard.
  6. Add context. Numbers are more useful with a short explanation next to them, especially if you’re sharing the dashboard and would like your team to understand the content easily:
    • Add a short summary above the charts explaining the main trend.
  7. Save or share your dashboard. How you do this depends on your AI tool:
    • In Claude, you can turn the result into a shareable artifact. See the steps in Supermetrics for Claude.
    • In ChatGPT and other AI tools, ask the tool how to share the dashboard, or check your AI tool's own documentation for how to save or export a chat result.
    • You can push the dashboards to Supermetrics Studio and share from there.
Once you're comfortable with this flow, head over to our AI use case examples article for more inspiration. Our instructions for Claude, ChatGPT, Microsoft Copilot, and Gemini Enterprise also list some use case examples.
Tips for success
  • Start simple: Begin with basic questions about your data before diving into complex, multi-platform analysis.
  • Be specific: Instead of asking for "performance data," be more specific, like "show me Google Ads click-through rates for last week."
  • Combine platforms: The real power comes from comparing and combining data. Try asking, "Create a summary comparing all my clients' Facebook ad performance this month."
  • Ask follow-ups: If you see interesting trends in the response, ask your AI to "dig deeper" or "explain what might be causing them."
AI chats isn't available to add to your subscription
AI chats is a separate destination to add to your Supermetrics subscription, so it doesn't come with every package automatically. Check your subscriptions on the Supermetrics Hub. You can also swap one of your existing destinations to AI chats.
If you are using an LLM that Supermetrics does not offer a ready-made plugin for, you can still connect it via the Supermetrics MCP server. Read more about the Supermetrics MCP server.
Note that the Supermetrics MCP server via Supermetrics API doesn’t include access to AI chats. To use Supermetrics with Claude, ChatGPT, or Copilot, you need the AI chats subscription or trial, not the Supermetrics API.
If your package should include AI chats and it's still not showing up, contact our support team.
AI chat shows a trial or subscription error even though you've paid
When you use a Supermetrics integration in AI tools, such as Claude or the Supermetrics MCP, the connection to Supermetrics is associated with the subscription active at the time of first connection. This can also be your trial subscription. When you later purchase a Supermetrics subscription using a different email address, the AI chats and Supermetrics MCP will retain the connection using the previous email address and team. This means that your active subscription may not be recognized. You may also see a LICENSE_NOT_FOUND error.
To resolve this issue and switch to the active subscription in your AI tool:
  1. Verify which email address and team are tied to your paid Supermetrics subscription.
  2. Disconnect the Supermetrics connector in the AI chat or the Supermetrics MCP.
  3. Reconnect Supermetrics again, this time with the email address and team associated with the paid subscription.
If this doesn’t resolve the issue, contact our support team.
How different AI platforms use data for training
Before you start prompting and using the AI platforms to get insights of your marketing data with Supermetrics, it’s important to understand how your inputs are handled.
How your data is used for model training depends entirely on the AI platform you choose and your specific subscription level. While most providers allow you to manage your privacy through opt-in or opt-out settings, these defaults vary significantly between personal and enterprise accounts.
  • Claude
    • Claude Free, Pro, and Max personal accounts and Team accounts use your data for training purposes, but you can opt out.
    • Claude Enterprise or API accounts don't use your data for training purposes.
  • ChatGPT
    • ChatGPT Free, Plus, and Pro accounts use your data for training purposes, but you can opt out.
    • ChatGPT Business or Enterprise accounts, or the OpenAI API account don't use your data, but you can opt in.
  • Google Gemini
    • Free Gemini accounts and paid Google AI Plus, AI Pro, and AI Ultra accounts use your data for training purposes, but you can opt out.
    • Google Workspace or API accounts don't use your data, but you can opt in.
    • Gemini Enterprise accounts don't use your data for training purposes.
  • Microsoft Copilot
    • Free or paid personal Microsoft 365 accounts use your data for training purposes, but you can opt out.
    • Microsoft 365 Copilot Business accounts, Enterprise accounts, and API-based services don't use your data for training purposes.
Disclaimer
This article is provided for informational purposes only and does not constitute legal advice. The information is based on publicly available documentation, terms and statements from the respective providers at the time of writing.
Please note that third-party providers may unilaterally change their policies, terms, or data usage practices at any time. Supermetrics does not guarantee the accuracy, completeness, or ongoing validity of this information.
Customers should review the official documentation of the relevant AI provider for the most current information. Supermetrics accepts no liability for any decisions or actions taken based on the information provided.
