You can connect to all your data sources from the Supermetrics Hub. You can add new connections and share links with external stakeholders to connect to different data sources.
More ways to bring your data to Supermetrics
While we have a wide range of data sources available, sometimes you may need something that we don’t yet have. For those situations, check out our guide on choosing how to connect your data — it’ll guide you through the options of building your own connector or working with offline data using Custom data import.
Getting connected on the Supermetrics Hub
On the Data Sources page on the Hub, you can manage your active connections to data sources and add new ones. At the top, you see a list of data sources you have already connected to. Below is a list of data sources that you can connect to.
Take a look at our tutorial video on how to connect to data sources, share the authentication link, and reconnect to the data source to resolve connection issues.
Note
When you log in to the Supermetrics Hub for the first time, you need to register your account using this link.
Connect to new data source
On the Supermetrics Hub, go to Data sources under Connect.
Scroll down to the list of data sources you haven't connected to. You see this list below your existing connections, under the title Connect to new data source.
Hover over the new data source, and click Connect.
Choose to make this connection shared or private.
Depending on the data source, enter your credentials and click Start, or click Start directly and then log in to the data source. See our data source guides for the details and permissions each data source requires to connect.
Add new connection
Go to the list of data sources you have connected to.
Click the data source.
Click Add new connection.
Share authentication link
If you need to connect to a data source that you don't have direct access to, you can share an authentication link with someone outside your organization. The person you share the link with must click the link and authenticate the connection to the data source. See detailed instructions for each data source in our data source guides.
Click Share authentication link. You can now share the authentication link with the person who has the necessary credentials. The authentication link is valid for 12 hours.
