Apple Public Data connection guide
This guide contains all permissions and requirements for connecting your Apple Public Data data to Supermetrics.
The Apple Public Data data source connector doesn't require authentication or connection to the App store.
  • App store
    • App Store search
    • App Store reviews
    • Top App Store apps
  • Books
    • Audiobook search
    • Book search
    • Top audiobooks
    • Top books
  • Music
    • Music search
    • Top Apple Music
    • Top iTunes Music
    • Top music videos
  • TV
    • Movie search
    • Short film search
    • TV show search
    • Top movies
    • Top TV shows
    • Top short films
  • Podcasts
    • Podcast search
    • Top podcasts
  • Other
    • Top iTunes U courses
When connecting to Apple Public Data, you need to select a query type when prompted.
  1. Select the Apple Public Data data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. In your data destination, select the query type and query details.
You can also connect to Apple Public Data from these destinations:
