This guide contains all permissions and requirements for connecting your Adform data to Supermetrics.
To connect to Adform, you need:
External API access enabled
An account with the Advertiser or Agency user role as part of the Buyer Solution category. Learn more in Adform's API documentation.
When connecting to Adform, you need to log in to Adform and select an account to pull data from when prompted.
Select the Adform data source on the Supermetrics Hub or in the data destination.
Log in to your Adform account.
Click Allow.
In your data destination, select the account to pull data from and an additional tracking filter ID.
You can also connect to Adform from these destinations:
AI tools and dashboards:
Spreadsheet and visualization tools:
