Adform report building guide
Use the Adform data source connector to pull data from multiple campaigns in one report to see which one is working the best and in which locations are your ads performing the best. You can also combine the data with your social media ads to have an overview of your campaign’s success.
Popular queries
See cost and number of tracked ads
Take a look at the cost and number of tracked ads of your campaigns on the monthly level. In this example, we take a look at the data for this year, and split the results by campaign and month.
Setting
Value
Date range
Year to date
Metrics
Cost, Tracked ads
Dimensions
Campaign, Month
Suggested visualization
Table
Understanding the data
  • Cost: Shows the cost value for the selected dimension (usually on a media or placement (line item) level).
  • Tracked ads: Shows the number of tracked ads (formerly known as impressions) and includes both rendered and served-but-not-rendered ads.
See clicks and tracked ads
Get data on the number of clicks and tracked ads for the last 28 days.
Setting
Value
Date range
Last 28 days
Metrics
Tracked Ads, Clicks
Dimensions
Date
Time series or line chart
  • Tracked Ads: Shows the number of tracked ads (formerly known as impressions) and includes both rendered and served-but-not-rendered ads.
  • Clicks: Shows the number of clicks for the selected dimension. A click occurs when a user interacts with the advertisement by engaging a mouse button (usually the left) while the mouse pointer is hovering over the advertisement.
See conversions
Take a look at your conversions from the past week. In this example, we include campaign, line item, and tracking point details in the query.
Setting
Value
Date range
Last week
Metrics
Conversions
Dimensions
Campaign, Date, Line item, Tracking point, Tracking point ID
Table
  • Conversions: Shows the number of all Conversion pageviews, displayed as a sum for all tracked conversion pages. It has predefined Uniqueness of 'No Repeat', which means that Conversion pageviews, generated by the same user within 15 minutes, are excluded.
See booked impressions for campaigns per media
Explore the booked impressions of your campaigns per media.
Setting
Value
Date range
Last week
Metrics
Booked impressions
Dimensions
Campaign, Media
Table
  • Booked impressions: Shows the number of booked impressions for the selected dimension. An impression occurs when a user is exposed to an advertisement.
