This guide contains all permissions and requirements for connecting your TikTok Ads data to Supermetrics.
Your TikTok account needs at least Ad account analyst access to connect. User roles with higher permissions — including Owner, Admin, and Operator — will also work.
Learn how to manage your account permissions in the TikTok Business Center.
When connecting to TikTok Ads, you need to log in to TikTok and select the accounts to use when prompted.
Select the TikTok Ads data source on the Supermetrics Hub or in the data destination.
Enter your email and password, and click Log in.
Click Agree, and then Confirm.
In your data destination, select the accounts to include in your reporting.
You can also connect to TikTok Ads from these destinations:
