This guide contains all permissions and requirements for connecting your Spotify Ads data to Supermetrics.
To connect your Spotify Ads data to Supermetrics, you need a Spotify account.
When connecting to Spotify Ads, you need to log in to Spotify and select the accounts to pull data from.
Select the Spotify Ads data source on the Supermetrics Hub or in the data destination.
Log in with the account you use to log in to Spotify, or log in with a Facebook, Apple, or Google Account (this doesn't need to be the same Google Account you use to log in to Supermetrics).
Click Log in.
Click Agree.
In your data destination, select the accounts to include in your reporting.
You can also connect to Spotify Ads from these destinations:
AI tools and dashboards:
Supermetrics APIs: How to get started with the Supermetrics APIs — You can also create Data API query URLs in Data Explorer.
