This guide contains all permissions and requirements for connecting your Snowflake data to Supermetrics.
Note
This guide is for the legacy version of the Snowflake connector. For the new Snowflake connector, see Snowflake connection guide.
We strongly recommend that all new and existing users migrate to the new connector, as it is our focus for future enhancements and development.
There are 2 ways to authenticate Snowflake: with OAuth, or with a username and password.
Note that in 2025, Snowflake will require moving to key-pair authentication. Using OAuth meets the need for mandatory key-pair or multi-factor authentication.
To connect with OAuth, you need an account with the Account admin role, plus a client ID and client secret.
How to create an OAuth client ID and client secret
Log in to Snowflake and click SYSADMIN.
Click Change, and select the ACCOUNTADMIN role.
Run the following 2 commands in a worksheet:
First command:
CREATE SECURITY INTEGRATION"Supermetrics App"TYPE = OAUTHENABLED = TRUEOAUTH_CLIENT = CUSTOMOAUTH_CLIENT_TYPE = 'CONFIDENTIAL'OAUTH_REDIRECT_URI = 'https://supermetrics.com/login-complete';Second command:
SELECT SYSTEM$SHOW_OAUTH_CLIENT_SECRETS('Supermetrics App');
Click row 1 in the output. You'll find this at the bottom of the screen.
A popup will open with 3 key-value pairs in JSON format.
Copy the values after the keys
OAUTH_CLIENT_IDandOAUTH_CLIENT_SECRET. These are your client ID and client secret — keep them safe.
To connect with a username and password, you need a database username and secret key with username, password, hostname, warehouse name, database name, and database schema.
How to find your hostname, database name, and database schema
You can find your hostname in the URL when you're logged in to Snowflake. It should end in snowflakecomputing.com.
The warehouse name, database name, and database schema can be found in Snowflake at the top right of the query editor.
IP allowlisting
To enable Supermetrics for Snowflake, your database needs to accept connections from the Supermetrics IP addresses. See this article for the IP addresses you need to allowlist.
You need to select one of the following query types when pulling data:
Database table-based report: Select a table from a schema, and use the columns of that table as the fields in Data Studio.
Make sure to check the "Warehouse, database name, and schema are case sensitive" option on the Snowflake login screen to enable this report type to work properly.
Date control doesn't work with this report type.
If the account you're using has multiple roles and the default role doesn't give it the permissions it needs to retrieve the table list, you might encounter problems getting your full list of tables. Change the account's default role or create a new account with only one role to solve the issue.
Database query report: Build an SQL query and use it to create report fields. With the SQL query, combine data from several tables, including those that are in different schemas.
Use this SQL workaround to use Date Control with this report type:
select * from MARKETING.MIX_PBI.GOOGLEADS_ADwhere DATE >= '#start-date#'AND DATE <= '#end-date#'
Note that SQL comments and Snowflake functions aren't supported in SQL-based reports.
When connecting to Snowflake, you need to log in to Snowflake.
Select the Snowflake data source on the Supermetrics Hub or in the data destination.
Select an authentication method.
Enter your credentials and click Start.
Create an SQL query under Query SQL.
You can also connect to Snowflake from these destinations:
Supermetrics APIs: How to get started with the Supermetrics APIs — You can also create Data API query URLs in Data Explorer.
