Snapchat Marketing connection guide
This guide contains all permissions and requirements for connecting your Snapchat Marketing data to Supermetrics.
Your Snapchat user account needs at least Account Admin or Campaign Manager access to an ad account before you can connect it to Supermetrics.
When connecting to Snapchat Marketing, you need to log in to Snapchat and select the accounts to use in your reporting when prompted.
  1. Select the Snapchat Marketing data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Enter your account details, and click Continue.
  5. Click Continue a second time.
  6. In your data destination, select the accounts to include in your query.
You can also connect to Snapchat Marketing from these destinations:
