Outbrain DSP (Zemanta) connection guide
This guide contains all permissions and requirements for connecting your Outbrain DSP (Zemanta) data to Supermetrics.
To connect Supermetrics to your Outbrain DSP (Zemanta) account, you need to create a client ID and client secret.
Create client ID and client secret
  1. Log in to Outbrain DSP (Zemanta) using this link.
  2. Click New Application.
  3. Enter a name for the application, for example, “Supermetrics”.
  4. Click Save.
  5. Copy the client ID and client secret and store them in a secure place for later use.
  • Performance: Measure the performance of your campaigns in Outbrain DSP (Zemanta).
When connecting to Outbrain DSP (Zemanta), you need to provide your client ID and client secret and select the accounts to pull data from.
  1. Select the Outbrain DSP (Zemanta) data source on the Supermetrics Hub or in the data destination.
  2. Enter your client ID and client secret.
  3. Give your login a name to recognize the login later if you have multiple logins.
  5. Click Start.
  6. In your data destination, select the accounts to use in your reporting and a query type to use, if prompted.
You can also connect to Outbrain DSP (Zemanta) from these destinations:
