Liftoff connection guide
This guide contains all permissions and requirements for connecting your Liftoff data to Supermetrics.
Before using the Liftoff connector, you will need the API key and API Secret for your Liftoff account. Contact your Liftoff Account Manager to get your API key and API Secret emailed to you. Once you have received the key and secret, copy and store it securely.
  • Campaign performance: Measure the performance of your marketing campaigns in Liftoff.
When connecting to Liftoff, you need to enter your API key and API Secret and select the query type if prompted.
  1. Select the Liftoff data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. In your data destination, select the organizations to include in your reporting and a query type, if prompted.
You can also connect to Liftoff from these destinations:
