This guide contains all permissions and requirements for connecting your Integral Ad Science data to Supermetrics.
To connect Supermetrics to your Integral Ad Science account, you need the username and password of your Integral Ad Science account.
Performance: Report performance of your ad campaigns on campaign, advertiser, team, placement, device or app level.
When connecting to Integral Ad Science, you need to enter your IAS username and password and select the ias team to use when prompted.
Select the Integral Ad Science data source on the Supermetrics Hub or in the data destination.
Enter your Integral Ad Science username and password.
In your data destination, select an IAS team to use in your report and a query type, if prompted.
You can also connect to Integral Ad Science from these destinations:
AI tools and dashboards:
