This guide contains all permissions and requirements for connecting your Instagram Insights data to Supermetrics.
If you'd like to connect your Instagram Public Data to your report, take a look at our Instagram Public Data connection guide.
There are two ways to connect to Instagram Insights:
Connect with Instagram login (recommended)
Connect with Facebook login
These authentication methods work differently and offer distinct advantages.
Authentication method | Details |
Instagram login |
Facebook login |
When connecting to Instagram Insights, you need to select an authentication method and log in.
Connect using Instagram login
Select the Instagram Insights data source on the Supermetrics Hub or in the data destination.
Click Start and log in with your Instagram account.
Enable the Access and manage insights toggle, and click Allow.
Review the permissions and click Save.
Connect using Facebook login
Click Start and log in with your Facebook account.
Select the Businesses, Pages, or Accounts you want to include in your reporting.
In your data destination, select the pages to include in your reporting.
You can also connect to Instagram Insights from these destinations:
AI tools and dashboards:
