Facebook Public Data connection guide
This guide contains all permissions and requirements for connecting your Facebook Public Data data to Supermetrics.
The Facebook Public Data data source connector doesn't require authentication or connection to Facebook.
To query data, you need the Facebook Page's alias. The alias is the name that follows the www.facebook.com/ address. For example, for www.facebook.com/Supermetrics, the alias is 'Supermetrics'.
  • Facebook Page data: Page data, including Likes, About, and the website link.
  • Facebook posts by a Page: Information on posts made to the Page, such as Post link, Reaction counts, and Comment counts.
  • Facebook shares for URLs: Data about specific shared URLs, like URL, Share count, and Comment count.
When connecting to Facebook Public Data, you need to select a query type to use and enter the Page aliases or Page IDs when prompted.
  1. Select the Facebook Public Data data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. In your data destination, enter the Page aliases or Page IDs to query and select a query type to use.
You can also connect to Facebook Public Data from these destinations:
