This guide contains all permissions and requirements for connecting your Ahrefs data to Supermetrics.
Ahrefs and Ahrefs (legacy)
We introduced a new version of our Ahrefs data source connector in February 2024. We updated this connector on October 29, 2025 to allow customers on any Ahrefs plan to connect using your Ahrefs login details. The Ahrefs (legacy) connector was fully deprecated and stopped working on October 31, 2025.
To connect Supermetrics to Ahrefs, you need:
An Admin or Owner user role level. See Ahrefs' documentation about member roles and access levels and how to add a new user to your account.
Multiple user accounts
It's not possible to add multiple user accounts in the same login for Ahrefs. To log in with a different user account, you need to log out from all other Ahrefs accounts in Supermetrics.
Target URL
We support HTTP, HTTPS, and WWW for the Target URL field.
Overview: Pull overview metrics from Backlink profile, Organic search and Paid search.
Backlinks: Understand specific referring pages yielding high and/or low traffic and their overall domain rating
Referring domains: Shows website domains for which target URL is referring
Organic keywords: Shows the organic keywords for which the target URL ranks for
Top pages: Shows which pages of the target URL get the most organic search traffic
Paid pages: Shows which pages of the target URL get the most paid search traffic
Keyword explorer: Overview: Get relevant keyword ideas with search volume, keyword difficulty, and other advanced metrics
When connecting to Ahrefs, you need to log in to Ahrefs and select the target URL when prompted.
Select the Ahrefs data source on the Supermetrics Hub or in the data destination.
Enter your credentials and click Log in.
In your data destination, select the query type and add the target URL.
Ahrefs connections have a maximum lifetime of one year. This means that the connection will expire after a year and you will need to log in again.
You can also connect to Ahrefs from these destinations:
AI tools and dashboards:
