This guide contains all permissions and requirements for connecting your AdRoll data to Supermetrics.
To connect Supermetrics to AdRoll, you need Administrator or General User role access. Learn how to add or edit an AdRoll user in AdRoll's documentation.
When connecting to AdRoll, you need to log in to AdRoll and select the account to pull data from when prompted.
Select the AdRoll data source on the Supermetrics Hub or in the data destination.
Enter your email and password, and click Sign in.
Click Authorize.
In your data destination, select the account to pull data from.
You can also connect to AdRoll from these destinations:
AI tools and dashboards:
