Vibe connection guide
This guide contains all permissions and requirements for connecting your Vibe data to Supermetrics.
Before using the Vibe connector, you need to create an API key on the Vibe platform.
To create your API key:
  1. In your Vibe account, navigate to SettingsAPI Keys.
  2. Click + Create API key.
  3. Give a meaningful name for the key that helps you identify which integration it’s used for.
  4. Once the key is created, copy and store it securely. Note that you’ll only be shown the full key once — after that, only a shortened reference will appear in your settings.
  • Campaign performance: Pull all the dimensions and metrics for your CTV campaigns, for different timezones and attribution windows.
When connecting to Vibe, you need to enter your API key and select the advertisers to use when prompted.
  1. Select the Vibe data source on the Supermetrics Hub or in the data destination.
  2. Insert your API key for Vibe.
  4. Click Start.
  5. In your data destination, select the advertisers to include in your reporting, and a query type, if prompted.
You can also connect to Vibe from these destinations:
