This guide contains all permissions and requirements for connecting your LinkedIn Ads data to Supermetrics.
To connect to LinkedIn Ads, you need:
A LinkedIn account with at least Viewer access to an ad account. Learn how to grant access to LinkedIn accounts.
Admin access to the Company Page is required for creative-level (ad content and metadata) granularity.
When connecting to LinkedIn Ads, you need to log in to LinkedIn and select the accounts to use when prompted.
Select the LinkedIn Ads data source on the Supermetrics Hub or in the data destination.
Enter your credentials and click Sign in.
In your data destination, select the accounts to pull data from.
You can also connect to LinkedIn Ads from these destinations:
AI tools and dashboards:
