LinkedIn Ads report building guide
Use the LinkedIn Ads data source connector to create an overall view of what gets the attention of your audience. Combine this data with data from other paid media channels to see which channel drives the most conversions and compare the quality and price per conversion.
Popular queries
Compare conversions and ad spend over time
See how your total ad spend and conversions have trended day by day over the last 28 days — useful for spotting whether spend and conversion volume are moving in the same direction and identifying any efficiency gaps.
Setting
Value
Date range
Last 28 days
Metrics
Total spent, Conversions
Dimensions
Date
Suggested visualization
Time series or combo chart
Understanding the data
  • Total spent: The campaign cost in the currency of your advertising account.
  • Conversions: The count of conversions indicated by pixel loads.
  • Date: Splits results by day so you can track spend and conversion trends together.
Note
Ad spend is given in the currency used by your LinkedIn Ads data source. You can convert the currency to other currencies in Google Sheets and Looker Studio. Learn more about currency conversion.
Break down conversions by type
See what types of conversions your LinkedIn Ads campaigns are generating year to date — useful for understanding which conversion actions are most common and evaluating campaign objective alignment.
Setting
Value
Date range
Year to date
Metrics
Conversions
Dimensions
Conversion type
Table
  • Conversion type: The type of conversion action tracked, used to compare volumes across different conversion goals.
Note: Many other metrics are not compatible with the Conversion type dimension and cannot be queried at the same time — they may return an error or empty values. This is a limitation of the LinkedIn API, which does not allow other dimensions or join keys alongside conversion-specific dimensions.
Review clicks, impressions, and spend by campaign last month
See how many times your ads were seen and clicked last month alongside your total spend, broken down by campaign — useful for comparing visibility, engagement, and budget efficiency across campaigns.
Setting
Value
Date range
Last month
Metrics
Clicks, Impressions, Total spent
Dimensions
Campaign name
Time series chart
  • Clicks: The count of chargeable clicks on your ads.
  • Impressions: The count of impressions for Direct Ads and Sponsored Updates, and sends for InMails.
  • Campaign name: Splits results by campaign for side-by-side performance comparison.
Analyze clicks, impressions, leads, and spend by campaign last week
Get a detailed view of last week's campaign performance — combining clicks, impressions, lead generation, and spend — to identify which campaigns are most efficiently converting attention into leads.
Setting
Value
Date range
Last week
Metrics
Clicks, Impressions, Leads, Total spent
Dimensions
Campaign name
Table
  • Leads: The count of leads generated through One Click Lead Gen.
Estimate total reach by campaign
See the approximate reach and total impressions for each campaign last week — useful for understanding how many unique people your campaigns are targeting and how often they're being seen.
Setting
Value
Date range
Last week
Metrics
Reach, Impressions
Dimensions
Campaign name
Table or bar chart
  • Reach: The approximate number of unique people targeted by your campaign.
  • Impressions: The total count of times your ads were shown, including repeat views by the same person.
  • Campaign name: Splits results by campaign so you can compare reach and impression volume across campaigns.
See the Supermetrics blog for posts about LinkedIn Ads and tips for social media marketing funnel.
