Instagram Insights connection guide
This guide contains all permissions and requirements for connecting your Instagram Insights data to Supermetrics.
If you'd like to connect your Instagram Public Data to your report, take a look at our Instagram Public Data connection guide.
There are two ways to connect to Instagram Insights:
  • Connect with Instagram login (recommended)
  • Connect with Facebook login
These authentication methods work differently and offer distinct advantages.
Authentication method
Details
Instagram login
  • Instagram account must be an Instagram Business account (sometimes called a "professional account"), or a Creator account that isn't restricted, age-limited, or private.
  • Authentication is persistent and doesn’t require manual re-authentication.
  • You can connect to one Instagram account at a time. To use multiple accounts with the Instagram login, create separate connections to each Instagram account.
  • Note that not all fields and features are available with the Instagram login. Learn how to identify what isn't available with this login.
Facebook login
  • Instagram account must:
  • Facebook account must:
    • Be a Facebook user account with Insights permissions.
    • If it's using the new Pages experience, the account needs Full control access to the Facebook Page linked to the Instagram account.
  • Authentication lasts for 60 days, after which the connection must be manually re-authenticated.
When connecting to Instagram Insights, you need to select an authentication method and log in.
Connect using Instagram login
  1. Select the Instagram Insights data source on the Supermetrics Hub or in the data destination.
  3. Click Start and log in with your Instagram account.
  4. Enable the Access and manage insights toggle, and click Allow.
  5. Review the permissions and click Save.
Connect using Facebook login
  3. Click Start and log in with your Facebook account.
  4. Select the Businesses, Pages, or Accounts you want to include in your reporting.
  6. In your data destination, select the pages to include in your reporting.
You can also connect to Instagram Insights from these destinations:
