Clockify connection guide
This guide contains all permissions and requirements for connecting your Clockify data to Supermetrics.
To connect Supermetrics to Clockify, you need:
When connecting to Clockify, you need to provide your API key and select the accounts to use when prompted.
  1. Select the Clockify data source on the Supermetrics Hub or in the data destination.
  2. Enter your API key.
  5. Click Start.
  6. In your data destination, select the accounts to use in your query.
You can also connect to Clockify from these destinations:
