This guide contains all permissions and requirements for connecting your Clockify data to Supermetrics.
To connect Supermetrics to Clockify, you need:
An account with the Admin user role (or higher). Learn more about Clockify user roles and permissions.
An API key. You can generate the API key under Profile settings in Clockify. Remember to keep this safe once you have it. Learn how to generate an API key in Clockify.
When connecting to Clockify, you need to provide your API key and select the accounts to use when prompted.
Select the Clockify data source on the Supermetrics Hub or in the data destination.
Enter your API key.
In your data destination, select the accounts to use in your query.
You can also connect to Clockify from these destinations:
AI tools and dashboards:
