This guide contains all permissions and requirements for connecting your Amazon DSP data to Supermetrics.
Availability
Due to Amazon’s policies, Amazon DSP is available only in Excel, data warehouse, and API data destinations.
To connect, you need an Amazon user account with access to an Amazon DSP advertiser account.
Required permissions:
Advertiser account:
Admin or ADSP reports account permission.
User account:
View or Edit permissions for the advertiser account.
For more details on the access requirements, see Amazon Ads Advanced Tools Center.
Note that the Amazon DSP data source can fetch a maximum of 50 linked accounts per manager account due to a limitation in the Amazon API. To work around this limitation and access more accounts, you can distribute them across multiple manager accounts and link them hierarchically to maintain full visibility. Note that the viability of this option depends on our account structure. Learn more in Amazon’s documentation.
Campaign: Get detailed performance metrics by order, line-item, and creative.
Inventory: Get detailed performance metrics by supply and site
When connecting to Amazon DSP, you need to log in to Amazon and select the query type and account when prompted.
Select the Amazon DSP data source on the Supermetrics Hub or in the data destination.
Select your account's region.
Give your account a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
Log in to your Amazon account.
Click Allow to give the Supermetrics app to access your profile data.
In your data destination, select the query type to use and an account to pull data from.
You can also connect to Amazon DSP from these destinations:
AI tools and dashboards:
