Adtraction connection guide
This guide contains all permissions and requirements for connecting your Adtraction data to Supermetrics.
To connect Supermetrics to Adtraction, you need an Adtraction API token. These are also referred to as API keys.
To generate this token:
  1. Log in to Adtraction.
  2. Navigate to Account → Settings.
  3. Select API from the navigation menu.
  4. Copy the API token. Remember to keep it safe.
Reference list: Adtraction query types
  • Advertiser: Channels
  • Advertiser: Clicks
  • Advertiser: Transactions
  • Advertiser: Statistics
  • Advertiser: Statistics by ad
  • Advertiser: Statistics by channel
  • Advertiser: Statistics by day
  • Advertiser: Statistics by segment
  • Affiliate: Markets
  • Affiliate: Channels
  • Affiliate: Currencies
  • Affiliate: Applications
  • Affiliate: Clicks
  • Affiliate: Transactions
  • Affiliate: Latest transactions
  • Affiliate: Statistics
  • Affiliate: Statistics by ads
  • Affiliate: Statistics by channel
  • Affiliate: Statistics by day
  • Affiliate: Statistics by EPI
  • Affiliate: Statistics by program
If you're logged with an API token belonging to an advertiser account, you can only use the report types intended for advertiser users. The same applies to affiliate accounts.
When connecting to Adtraction, you need to insert your API key (API token) and select the query details when prompted.
  1. Select the Adtraction data source on the Supermetrics Hub or in the data destination.
  2. Enter your API key.
  5. Click Start.
  6. In your data destination, select the query type and other options depending on the selected query type.
You can also connect to Adtraction from these destinations:
