This guide contains all permissions and requirements for connecting your Adtraction data to Supermetrics.
To connect Supermetrics to Adtraction, you need an Adtraction API token. These are also referred to as API keys.
To generate this token:
Navigate to Account → Settings.
Select API from the navigation menu.
Copy the API token. Remember to keep it safe.
Reference list: Adtraction query types
Advertiser: Channels
Advertiser: Clicks
Advertiser: Transactions
Advertiser: Statistics
Advertiser: Statistics by ad
Advertiser: Statistics by channel
Advertiser: Statistics by day
Advertiser: Statistics by segment
Affiliate: Markets
Affiliate: Channels
Affiliate: Currencies
Affiliate: Applications
Affiliate: Clicks
Affiliate: Transactions
Affiliate: Latest transactions
Affiliate: Statistics
Affiliate: Statistics by ads
Affiliate: Statistics by channel
Affiliate: Statistics by day
Affiliate: Statistics by EPI
Affiliate: Statistics by program
If you're logged with an API token belonging to an advertiser account, you can only use the report types intended for advertiser users. The same applies to affiliate accounts.
When connecting to Adtraction, you need to insert your API key (API token) and select the query details when prompted.
Select the Adtraction data source on the Supermetrics Hub or in the data destination.
Enter your API key.
In your data destination, select the query type and other options depending on the selected query type.
You can also connect to Adtraction from these destinations:
AI tools and dashboards:
