The Supermetrics Hub is a place where you can manage your data sources, accounts, data integrations, and more.
You can connect to new data sources, start new trials, and explore all features.
Use the Data Explorer to take a quick look at your data, or build a query URL to use in other destinations.
To dig deeper into your data, you can create data blends and custom fields on the Hub and use them in your reporting.
And of course, the Hub is the place to manage your teams and subscription details.
Note
When you log in to the Supermetrics Hub for the first time, you need to register your account using this link.
Navigation on the Hub
In the left-side menu, you can access the following subpages:
Home: Your home page on the Supermetrics Hub.
Connect
Data sources: Connect to data sources and manage your data source connections.
Custom data import: About Supermetrics Customer Data Import.
Connector builder: Build your own custom connectors.
Manage
Custom fields: Create custom fields.
Data blending: Blend data from different data sources.
Data warehousing: Connect to data warehouse destinations.
Table manager: Transfer data to data warehouse destinations.
Data transfers: Monitor your transfers.
Analyze
Supermetrics Studio: Build live, AI-powered dashboards using Supermetrics connectors.
AI chats: Work on with your data directly in the AI tools you use, such as ChatGPT and Claude.
Destinations: Go to your external reporting tools — Google Sheets, Data Studio, Excel, and Power BI.
Data explorer: Analyze your marketing data directly on the Supermetrics Hub or export the data in various formats.
From the top bar, you can access the following menus:
Your team name: Click the team name to switch between teams
Help menu button (
):Links to our support center and status page
Links to useful resources to manage your account
View and submit support tickets
Your avatar:
Manage your team: Add and remove your Supermetrics team members and update their team roles.
Usage: View your data source usage.
API keys: Create and manage your API keys.
Subscriptions: Manage your Supermetrics subscriptions and assign users to them.
Billing details: View and update your billing information.
Log out: Log out of the Supermetrics Hub.
