This guide contains all permissions and requirements for connecting your Yandex.Direct data to Supermetrics.
To connect Yandex data sources, you need Chief Representative or Representative user access. Learn more about Yandex user roles.
When connecting to Yandex.Direct you need to log in to Yandex.
Select the Yandex.Direct data source on the Supermetrics Hub or in the data destination.
Enter your credentials, and click Log in.
Click Allow.
You can also connect to Yandex.Direct from these destinations:
AI tools and dashboards:
