Yandex.Direct and Yandex.Metrica: Query setup guide
Once you’ve authenticated your connection to Yandex.Direct and Yandex.Metrica, you’re ready to create your first query.
This guide will walk you through Yandex.Direct and Yandex.Metrica query setup for Google Sheets, Data Studio (formerly Looker Studio), and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and API.
To connect Supermetrics to Yandex.Direct, you need:
To connect Supermetrics to Yandex.Metrica, you need:
Available fields
See our documentation for a full list of the metrics and dimensions Supermetrics can pull from Yandex.Direct and Yandex.Metrica.
  1. Connect to the Yandex.Direct or Yandex.Metrica data source.
  2. Select Dates. Choose one date range (today, yesterday, last week, etc.). To select a custom date, you can insert the date manually in the Start and End fields in the calendar bar.
  3. Select Metrics.
  4. Select Split by Dimensions.You can choose to split your data into rows and/or columns, reflect the number of rows or columns to be fetched, and define how the data is sorted.
  5. Click Get Data to Table to create your query and pull your data.
  2. Under Dimension, select Dimensions.
  3. Under Metric, select Metrics.
  4. Select how to sort the data.
  5. Select the Date range from the auto or custom options. If you choose a custom date range, click the arrow on the top-right hand side. Under a specific period, select a Start Date and End Date.
  3. Select Metrics.
  5. Click Get data to create your query and pull your data.
Advanced options for Excel
  2. Under Options, you can add additional features to your query. Learn more about Supermetrics advanced settings in Excel.
