Each data source decides which metrics and dimensions you can use together in one query. This guide shows you how to find a combination that works. Use it if you see one of these messages:
These metrics and dimensions can't be fetched togetherIncompatible fieldsSelected field combination is invalid
This happens because one or more of the query’s fields can’t be requested together. Often, this is due to restrictions in the data source’s API.
These errors can also appear when the incompatible fields are included in filters and sorts, rather than in the query itself.
If the error message describes which metrics and dimensions are causing the issue, remove them from your query.
If the error doesn’t describe the metrics or dimensions causing the issue, remove metrics and dimensions from the query, one at a time, until the query runs. Once you have found the problem field(s), you can update the query to run without them.
If the field is essential to your reporting, you can work around the error by creating a second query with the incompatible field and another field that can be used as a join key (like IDs). You can then use spreadsheet functions to join the data together into one table with the key. In Data Studio (formerly Looker Studio), data blending can also do this.
Data sources with query type configurations
For queries that have multiple query types in the configuration (for example, Mailchimp, LinkedIn Company Pages, Semrush, and more), the error can be caused by a field that isn’t part of the query type.
Select a different query type to use the field with.
