This guide contains all permissions and requirements for connecting your Tripadvisor Reviews data to Supermetrics.
You need a business' location ID before you can pull its review data from Tripadvisor Reviews.
You can find any location ID by copying the 7-digit code that follows the -d in any business' Tripadvisor URL.
For example, if a venue's URL ended with /Restaurant_Review-g123456-d7891011-Reviews-Example_venue.html, the location ID would be 7891011.
Reviews: View up to 100 of the most recent reviews.
When connecting to Tripadvisor Reviews, you need to provide the business' location IDs to query.
Select the Tripadvisor Reviews data source on the Supermetrics Hub or in the data destination.
In your data destination, select a query type, if prompted, and enter the location ID to include in your reporting.
You can also connect to Tripadvisor Reviews from these destinations:
AI tools and dashboards:
