This guide contains all permissions and requirements for connecting your TikTok Organic data to Supermetrics.
To fetch data using the TikTok Organic data source connector, you need to connect to the data source using your TikTok Business or Personal account. Note that the personal account needs to have at least 100 followers, analytics enabled, and at least one public post to get data through the connector.
You log in to Supermetrics TikTok Organic connector with the same credentials that are used for logging in to the TikTok profile on the TikTok mobile app. It is not possible to log in with your TikTok account to get data from other accounts, even if you have been granted the permissions on TikTok.
Profile overview: Get profile-level data on how many people started to follow you, viewed your profile, or viewed or engaged with your profile. Profile data is available for the last 60 days and can be broken down on a daily level.
Video performance: Get video-level data on how many people viewed your video, engaged with your video, or how long your videos were watched on average. Video data is available as lifetime value per video. This means the video performance data can't be broken down for a specific date range or by date.
Followers by country: Get a percentage distribution of your follower base by country. Followers by country data is available for the last 60 days.
Followers by gender: Get a percentage distribution of your follower base by gender. Followers by gender data is available for the last 60 days.
When connecting to TikTok Organic, you need to log in to TikTok and select a query type when prompted.
Select the TikTok Organic data source on the Supermetrics Hub or in the data destination.
Log in to the TikTok account you want to fetch data from.
Click Authorize to allow the Supermetrics app to access your profile data.
In your data destination, select the query type to use in your reporting.
You can also connect to TikTok Organic from these destinations:
