Teads connection guide
This guide contains all permissions and requirements for connecting your Teads data to Supermetrics.
To connect Supermetrics to your Teads account, you need to create an API key.
Create an API key
  1. Log in to your Teads account.
  2. Click the gear icon in the header to open the Settings screen.
  3. Click Generate API key in the API keys section.
  4. Click the edit icon to change the API key name.
  5. Copy the API key shown under the name of the key. You need the key when connecting Teads to Supermetrics.
  • Reporting
When connecting to Teads, you need to provide your API key and select the timezone when prompted.
  1. Select the Teads data source on the Supermetrics Hub or in the data destination.
  2. Enter your API key.
  3. Give your login a name to recognize the login later if you have multiple logins.
  5. Click Start.
  6. In your data destination, select the timezone. You may also be asked to select accounts to pull data from and a query type.
You can also connect to Teads from these destinations:
