This guide contains all permissions and requirements for connecting your Sprout Social data to Supermetrics.
To connect Sprout Social to Supermetrics, you need:
An account that's been provisioned for API by the Sprout Social account owner
An API token
Your account's owner should follow Sprout Social's instructions to create this token.
Note that to fetch engagement data for X (Twitter), you need to approve additional permissions.
Posts performance: Measure your social media posts' user engagement.
Tags performance: List your social media tags.
When connecting to Sprout Social, you need to give your API key and select a query type when prompted.
Select the Sprout Social data source on the Supermetrics Hub or in the data destination.
Enter your API token.
Give your account a name to recognize the login later if you have multiple logins.
You can also connect to Sprout Social from these destinations:
