Sprinklr connection guide
This guide contains all permissions and requirements for connecting your Sprinklr data to Supermetrics.
To connect to Sprinklr, you need to create your own OAuth Application within the Sprinklr developer environment to obtain the required credentials. You’ll also need your specific Environment Parameter.
You can find the instructions to extract Environment from Sprinklr’s UI here or reach out to your Sprinklr admin or customer success manager.
You also need access to a Sprinklr user account with the following permissions:
  • Generate Token
  • Generate Widget API Payload
See Sprinklr’s documentation for details on how to manage roles in Sprinklr.
How to create an OAuth application and obtain your Environment Parameter
  1. Follow the steps in Sprinklr’s documentation.
  2. In the Register Application form, enter the following Callback URL: https://supermetrics.com/login-complete
  3. Once the application has been created, save your API Key (Client_ID) and API secret (client_secret) in a secure location.
Take note of your Environment Parameter, as it is required to authenticate the connector.
Note
Only one token can exist per API key. If you have multiple stateless instances, you’ll need to generate a separate API key and token paid for each instance. This means that if you plan to use the connector in multiple destinations, you must create a separate API key for each one. Alternatively, you can use a shared connection if you prefer a single setup across destinations.
  • Post performance: Measures the performance of individual social media posts.
When connecting to Sprinklr, you need to log in to Sprinklr and check the combination of workspaces that should have access to the token.
  1. Select the Sprinklr data source on the Supermetrics Hub or in the data destination.
  2. Insert the Client ID and Client Secret you obtained from your OAuth 2.0 Application, and select your Environment (ENV) from the dropdown list.
  4. Click Start.
    a. A Sprinklr login window will appear. Log in to your Sprinklr account.
    b. Authorize the Supermetrics application to access your data.
  5. In your data destination, select the account(s) you want to pull data from.
You can also connect to Sprinklr from these destinations:
