This guide contains all permissions and requirements for connecting your Snowflake data to Supermetrics.
There are two methods to authenticate your Snowflake connection, with OAuth2 or with a key-pair authentication.
Note that you also need to set up authentication on the Snowflake side before connecting to Supermetrics.
Permissions when connecting with OAuth2
To connect with OAuth, you need the following:
Snowflake account with the Account admin role
OAuth client ID and client secret.
Account/Server URL
Full table name
Warehouse name
Permissions when connecting with a key-pair authentication
To connect with a key-pair authentication, you need the following:
Account/Server URL
Full table name
Username
Private key
Passphrase (enter “none” if the key is not encrypted)
Warehouse name
Note that these values are case sensitive when connecting to the Snowflake connector.
Please also note that the Snowflake table must include a DATE or DATETIME column to support date-range filtering in Supermetrics. You can identify compatible columns by opening the “Columns” tab of your table in Snowflake and sorting by Type.
Set up Snowflake
Step 1: Choose either OAuth2 or Key-pair authentication
For the first step, you will need to choose to authenticate the connection using either OAuth2 or key-pair authentication. Both methods are outlined below. Follow only the instructions for your selected method and continue with step 2.
How to create an OAuth client ID and client secret
Log in to Snowflake and click SYSADMIN.
Click Change, and select the ACCOUNTADMIN role.
Run the following 2 commands in a worksheet:
First command:
CREATE SECURITY INTEGRATION"Supermetrics App"TYPE = OAUTHENABLED = TRUEOAUTH_CLIENT = CUSTOMOAUTH_CLIENT_TYPE = 'CONFIDENTIAL'OAUTH_REDIRECT_URI = 'https://supermetrics.com/login-complete'
;Second command:
SELECT SYSTEM$SHOW_OAUTH_CLIENT_SECRETS('Supermetrics App');
Click row 1 in the output. You'll find this at the bottom of the screen. A popup will open with 3 key-value pairs in JSON format.
Copy the values after the keys
OAUTH_CLIENT_IDandOAUTH_CLIENT_SECRET. These are your client ID and client secret — keep them safe.
How to create your private key and passphrase
For encrypted keys (with passphrase):
Use OpenSSL to generate an encrypted private key and public key pair
openssl genrsa 2048 | openssl pkcs8 -topk8 -v2 des3 -inform PEM -out rsa_key.p8 openssl rsa -in rsa_key.p8 -pubout -out rsa_key.pubWhen prompted, create a passphrase to protect your private key
Have an admin with ACCOUNTADMIN role register you public key in Snowflake using this command:
ALTER USER username SET RSA_PUBLIC_KEY='MIIBIjANBgkqh...';To authenticate the connector, use the following value from the private key:
Private key: Copy the entire content of your private key file, including the beginning and end markers: -----BEGIN ENCRYPTED PRIVATE KEY----- to -----END ENCRYPTED PRIVATE KEY-----.
Passphrase: The password you created when generating your private key.
For unencrypted keys (without passphrase):
Use OpenSSL to generate an unencrypted private key and public key pair
openssl genrsa 2048 | openssl pkcs8 -topk8 -nocrypt -inform PEM -out rsa_key.p8 openssl rsa -in rsa_key.p8 -pubout -out rsa_key.pubHave an admin with ACCOUNTADMIN role register your public key in Snowflake using this command:
Private key: Copy the entire content of your private key file, including the begin and end markers: -----BEGIN PRIVATE KEY----- to -----END PRIVATE KEY-----
Passphrase: enter ‘none’ (case sensitive).
Step 2: Find your Account/Server URL
Log in to Snowflake.
In the bottom left, click your username.
Hover over Account in the menu that appears and click View account details.
Copy the value for Account/Server URL.
Step 3: Find your full table name
In the left side navigation, click Catalog → Database explorer.
Select the database and schema where your table is located.
Select the table you want to fetch data from.
Once you are at the selected table the database name, schema, and table name are displayed at the top, separated by slashes in this format:
DATABASE_NAME/SCHEMA_NAME/TABLE_NAMECopy these names and enter them in the following format when connecting in Supermetrics:
DATABASE_NAME.SCHEMA_NAME.TABLE_NAME
Step 4: Find your warehouse name
Open the Data preview tab.
The warehouse name is visible next to the number of rows. Copy the warehouse name.
IP allowlisting
If your database only accepts connections from approved IP addresses, add all Supermetrics IP addresses to your allowlist before connecting. See this article for the IP addresses you need to allowlist.
Table: Fetch data from your table in Snowflake.
When connecting to Snowflake using OAuth2
Select the Snowflake data source on the Supermetrics Hub or in the data destination.
Complete the OAuth login flow.
Create a query by selecting the desired metrics and dimensions.
Set a Date column under the Options tab. Note that the Date column is case-sensitive and required.
When connecting to Snowflake using a key-pair authentication
Enter your account URL, table name, username, private key, passphrase, warehouse, and click Start.
Create a query by selecting the desired metrics, and dimensions.
Set a Date column under the Options tab. Do note that the Date column is case-sensitive and required.
You can also connect to Snowflake from these destinations:
AI tools and dashboards:
