Shopee Ads connection guide
This guide contains all permissions and requirements for connecting your Shopee Ads data to Supermetrics.
To pull commerce data from Shopee using Supermetrics, you need a Shopee account.
In addition:
  • You must connect to Shopee using a normal Shop account that has access to a single shop per login. Main accounts and sub-accounts are not compatible with the connector.
  • You need the email/phone number/user name and password of the Shop account.
Learn more about different types of Shopee accounts.
  • CPC Ads: Retrieve performance data for CPC ads.
When connecting to Shopee Ads, you need to log in to Shopee Ads and select the shop region when prompted.
  1. Select the Shopee Ads data source on the Supermetrics Hub or in the data destination.
  2. Select your store region from the dropdown.
  4. Click Start.
  5. Select your store region from the dropdown and insert your email/phone number/user name and password.
  6. Confirm the authorization for Supermetrics to access your Shopee data.
  7. In your data destination, select the stores to include in your reporting and a query type, if prompted.
You can also connect to Shopee Ads from these destinations:
