Semrush Analytics connection guide
This guide contains all permissions and requirements for connecting your Semrush Analytics data to Supermetrics.
To connect Supermetrics to Semrush Analytics, you will need a paid Semrush subscription.
Note that each query made with Supermetrics will use up the subscription's Web Query allotment, which is defined by the type of subscription.
Semrush Analytics supports 5 main types of queries — Domain, Keyword, URLs, Display Ads, and Backlinks — for a total of 35 different query types.
Our connector uses the same structure as the API reports with the same names, so you can use the Semrush Analytics API documentation to explore the full range of reports and fields.
See our Semrush Analytics report building guide for more information about query types for this connector.
When connecting to Semrush Analytics you need to log in to Semrush and select the query type and enter the domains to query.
  1. Select the Semrush Analytics data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Enter your Semrush Analytics email and password, and click Log in.
  5. Click Approve.
  6. In your data destination, select a query type and enter one or more domains, separating each one with a comma with no whitespace (,).
You can also connect to Semrush Analytics from these destinations:
