Quantcast connection guide
This guide contains all permissions and requirements for connecting your Quantcast data to Supermetrics.
To connect Supermetrics to Quantcast, you need:
  • A copy of your account ID
  • An API key
  • An API secret
Get your account ID
  1. Log in to Quantcast.
  2. Click Account list in the top right.
  3. Click View all.
  4. Copy the account ID for the account you want to connect.
Get your API key and API secret
  2. In the top right, click the Profile icon, and then My profile.
  3. Navigate to the "API key" section, and click Create API Key.
  4. Quantcast will show your API key and API secret once. Copy these — remember to keep them safe and secure.
  • Campaigns: Measure the performance of your advertising campaigns.
When connecting to Quantcast, you need to provide your credentials.
  1. Select the Quantcast data source on the Supermetrics Hub or in the data destination.
  2. Enter the Account ID for the account you want to connect.
  3. Enter that account's API key and API secret.
  4. Give your login a name. The name can be anything — its purpose is for you to recognize the login later in case you have multiple logins.
  6. Click Start.
  7. In your data destination, select the query type, if prompted.
You can also connect to Quantcast from these destinations:
