Prisjakt connection guide
This guide contains all permissions and requirements for connecting your Prisjakt data to Supermetrics.
With Prisjakt, you can fetch data from the following price comparison websites:
  • Prisjakt (Sweden, Norway)
  • Prisjagt (Denmark)
  • PriceSpy (UK, New Zealand)
  • leDénicheur (France)
  • Hintaopas (Finland)
Before using the Prisjakt connector, you need a client ID and client secret. To get your client ID and client secret, reach out to your Prisjakt contact person. There is no self-service option at the moment.
Please note that each client ID and client secret has access to specific shops in Prisjakt. Make sure that your client ID and client secret have permissions to all relevant shops you want to use in Supermetrics.
  • Product performance: Pull a month-level report of the dimensions and metrics.
When connecting to Prisjakt, you need to provide your client ID and client secret.
  1. Select the Prisjakt data source on the Supermetrics Hub or in the data destination.
  3. Enter the client ID and client secret.
  4. Give your account a name. The name can be anything — its purpose is for you to recognize the account later in case you have multiple logins.
  5. Click Start.
  6. In your data destination, select the accounts to pull data from and a query type, if prompted.
You can also connect to Prisjakt from these destinations:
