Pipedrive connection guide
This guide contains all permissions and requirements for connecting your Pipedrive data to Supermetrics.
You need a Pipedrive account to pull data.
  • Leads: Retrieve detailed insights on your Pipedrive leads data.
  • Deals: Retrieve detailed insights on your Pipedrive deals data.
When connecting to Pipedrive, you need to log in to Pipedrive and select the accounts to use when prompted.
  1. Select the Pipedrive data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Log in to Pipedrive. If you're already logged in to Pipedrive in the browser, Supermetrics will use those credentials automatically.
  5. Click Continue to app.
  6. In your data destination, select the account to pull data from and a query type to use.
You can also connect to Pipedrive from these destinations:
