Pinterest Public Data connection guide
This guide contains all permissions and requirements for connecting your Pinterest Public Data data to Supermetrics.
Pinterest Public Data allows you to collect publicly available data about Pinterest posts. It doesn't require you to log in to a specific account.
  • Pinterest user: User information like account name, profile link, follower count, and more
  • Pinterest pins for users: Data on user pins, including Pin URL, image, description, and more
When connecting to Pinterest Public Data, you need add the Pins or usernames to include in the query when prompted.
  1. Select the Pinterest Public Data data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. In your data destination, select the query type to use.
  5. Add the Pinterest usernames. You can add more than one username, each on a new line.
You can also connect to Pinterest Public Data from these destinations:
