Outbrain Amplify connection guide
This guide contains all permissions and requirements for connecting your Outbrain Amplify data to Supermetrics.
To connect Supermetrics to Outbrain Amplify, you need API access from Outbrain.
When connecting to Outbrain Amplify, you need to provide your credentials and select the accounts to pull data from.
  1. Select the Outbrain Amplify data source on the Supermetrics Hub or in the data destination.
  2. Enter your username and password.
  4. Click Start.
  5. In your data destination, select the accounts to include in your reporting.
You can also connect to Outbrain Amplify from these destinations:
