MNTN connection guide
This guide contains all permissions and requirements for connecting your MNTN data to Supermetrics.
Before using the MNTN connector, you need your MNTN API key for the advertiser you want to connect to and fetch data for. To create an API key, you must sign in to MNTN and follow the instructions in MNTN’s documentation.
  • Performance: Fetch performance data for your MNTN advertising campaigns.
  1. Select the MNTN data source on the Supermetrics Hub or in the data destination.
  2. Enter your API key and give a name for your login.
  4. Click Start.
  5. In your data destination, select the advertisers to include in your reporting and a query type, if prompted.
You can also connect to MNTN from these destinations:
