Mixpanel connection guide
This guide contains all permissions and requirements for connecting your Mixpanel data to Supermetrics.
A Mixpanel service account is required to query the data in Supermetrics, and you must identify which Data Residency your Mixpanel project uses.
How to find your project’s Data Residency
  1. Log in to your Mixpanel dashboard.
  2. In the bottom left corner, click the cogwheel icon. Hover over Settings and select Project settings.
  3. In the Project Details table, the Data Residency will be visible.
How to create a service account
  3. Select Service accounts from the navigation menu on the left side.
  4. In the top right corner, click Add service account.
  5. Enter a name for your new service account, for example “Supermetrics”.
  6. Select Consumer as the project role.
  7. Click Add.
  8. Copy the Service account name and Service account secret to a secure location.
Learn more about service accounts in Mixpanel’s documentation.
  • Events: Get event data to track interactions between a user and your product.
When connecting to Mixpanel, you need to provide your account name and secret and select the data residency to use.
  1. Select the Mixpanel data source on the Supermetrics Hub or in the data destination.
  2. Select the Data residency of your Mixpanel Project.
  3. Enter your Mixpanel service account name and secret.
  4. Give your login a name to recognize the login later in case you have multiple logins.
  6. Click Start.
  7. In your data destination, select the data residency and a query type to use in your report, if prompted.
You can also connect to Mixpanel from these destinations:
