This guide contains all permissions and requirements for connecting your LY Ads Display Ads data to Supermetrics.
You need a Yahoo! Japan business account to connect to Supermetrics.
When connecting to LY Ads Display Ads, you need to log in to Yahoo! Japan.
Select the LY Ads Display Ads data source on the Supermetrics Hub or in the data destination.
Enter your Yahoo! Japan business account credentials.
Click Login, and then Approve.
You can also connect to LY Ads Display Ads from these destinations:
AI tools and dashboards:
