HubSpot connection guide
This guide contains all permissions and requirements for connecting your HubSpot data to Supermetrics.
To connect, you'll need a HubSpot account with either of these user roles:
  • Admin
  • Super Admin or Owner (full access)
When connecting to HubSpot, you need to log in to HubSpot.
  1. Select the HubSpot data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Log in to HubSpot.
  5. Select an account and click Choose account
  6. Select the scopes and click Connect app.
    Connecting Supermetrics to HubSpot, detailing required and optional access permissions.
  7. In your data destination, select the accounts to include in your reporting.
You can also connect to HubSpot from these destinations:
