Harvest connection guide
This guide contains all permissions and requirements for connecting your Harvest data to Supermetrics.
The Harvest API mirrors your account permissions. For this reason, you'll need access to an Administrator account to access your data. Learn more in Harvest's documentation.
Query types define what sort of metrics and dimensions are available. Each Harvest query type pulls time and billing data by the dimension in its name (for example, the Projects report pulls data by client or project). You need to select one of the following query types when pulling data:
Note that Project, Client, Task, and Team reports allow only reporting with monthly granularity.
  • Projects report
  • Clients report
  • Tasks report
  • Team report
  • Time entries (not available in Data Studio)
Harvest's API allows a maximum of 100 requests every 15 minutes. If you find any of your Harvest queries timing out, wait 15 minutes and try again.
When connecting to Harvest, you need to log in to Harvest and select the query type when prompted.
  1. Select the Harvest data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Sign in with your Harvest account.
  5. Click Authorize application.
  6. In your data destination, select the query type to use.
You can also connect to Harvest from these destinations:
