This guide contains all permissions and requirements for connecting your Criteo Retail Media data to Supermetrics.
Before using the Criteo Retail Media connector, you need:
An API user with a client ID and client secret.
An app with at least Read access for all elements of the Retail Media API.
To create these credentials, follow our Criteo permissions guide.
Campaign: An overview of the performance of a specific advertising campaign over a given period of time using the Clicks, Impressions, CTR, CPM, Attributed orders, Units, Sales, Cost, CPC, Unique visitors, and Frequency metrics
Page type: Campaign data split by Page type
Product: Campaign data split by Product
Keyword: Campaign data split by Keyword
Attributed transactions: Insights into the performance of ad campaigns by attributing conversions to specific advertising initiatives
When connecting to Criteo Retail Media, you need to provide your Criteo credentials.
Select the Criteo Retail Media data source on the Supermetrics Hub or in the data destination.
Enter the client ID and client secret.
Give your login a name to recognize the login later in case you have multiple logins.
In your data destination, select a query type to use.
You can also connect to Criteo Retail Media from these destinations:
AI tools and dashboards:
