Branch connection guide
This guide contains all permissions and requirements for connecting your Branch data to Supermetrics.
To connect Supermetrics to your Branch account, you'll need a Branch key and secret. Get the key and key secret from Branch Dashboard → Account Settings → Profile.
To access the Query API, you need to have both Aggregate Data and Export access. Learn more about the Query API in Branch help.
  • Summary (total): Get the raw organic data for app analytics from the Branch summary dashboard.
  • Summary (unique): Get the unique data for app analytics from the Branch summary dashboard.
Learn more about the Branch dashboard and the relevant query types and filters to use with Supermetrics.
When connecting to Branch, you need to provide your Branch key and secret.
  1. Select the Branch data source on the Supermetrics Hub or in the data destination.
  2. Enter your Branch key and secret.
  5. Click Start.
  6. In your data destination, select the query type to use.
You can also connect to Branch from these destinations:
